2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-06-22T10:54:28+00:00
    the BATTERY in Surface devices is not user replaceable.
    >> I wonder if MS is planning such a program.
    Barb
    MVP-Windows and Devices for IT
    2016-06-22T09:48:43+00:00
    The HP computer is also a problem with the batteries. HP launched a program to replace the battery. I wonder if MS is planning such a program.
    https://h30686.www3.hp.com/?lang=en-GB
    2016-06-22T09:37:39+00:00
    The Full Charge capacity of my SP3 is dropping very fast every day. It was 9500mWh on 19 Jun 2016. It is now only 7592 on 22 Jun 2016.
    I have been using other devises (e.g. iPad mini) and have never experience such drastic drop in batter capacity...
    Other than the problem with the battery, I actually like my SP3. Sadly, this will be the last time I will be buying a Surface Pro.
    2016-06-20T21:08:06+00:00
    I'm definitely not pleased with this (lack of) actions from Microsoft. I take a look at Reddit, and found several threads describing the same or similar issue as in this thread.
    https://redd.it/4oueqy Interestingly, the same defect also happening with Pro 2. The post stated that the owner has owned the machine for over 2 years, and it started happening after March.
    https://redd.it/4otmp1 The screenshot indicates that the battery start declining around May although the decline seems more steady. But that may be because the owner plug the machine in most of the time.
    https://redd.it/4nhfgn Same with Surface Pro 3.
    Other cases that might related, but without batteryreport.
    https://redd.it/4opty9 Surface Book, might be related.
    https://redd.it/4of0bs Might be related.
    From the looks of it, the cycle count doesn't really mattered and the problem seems to start happening sometimes after March (e.g. my case). I think it may be because a battery defect in the lot that were produced around the end of 2014 that did not shown any defects after 14~15 months of usage, or the problem triggered by a firmware update.
    Either way, I think there might be a lot more people who have this problem but haven't discovered it yet due to the battery not degraded enough to be noticeable. If they're unlucky (like us…), they will notice after the warranty expired.
    I think if anyone here know anyone who use Surface Pro, it's better to ask them to run powercfg /batteryreport and see if it is affecting them or not. I wonder if there is a way to make Microsoft notice s?
