2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-06-20T19:41:16+00:00
    I wonder if that owners are pleased with the actions of MS
    2016-06-20T14:51:23+00:00
    Microsoft will be lucky if it is only a few of us - I bet it will turn out to be 10% of owners
    2016-06-20T13:23:56+00:00
    I agree that it may be a hardware issue. I was trying to look for firmware/OS updates that coincide with when the battery began to wear but wasn't able to come up with anything for sure. My capacity began dropping the week of 5/15. There was the SP3 firmware update in April so I doubt it is that; and there was a Windows 10 update (KB3156421) which I installed on 5/14. Though it seems like, of the people posting, the drop is happening at different times.
    In any case, I am going to take my SP3 to the Microsoft Store in the next week or so and see what they can tell me. I'll update here.
    FWIW I also have a SIMPLO battery.
    2016-06-20T13:04:54+00:00
    The problem may be firmware but it might as well be a faulty battery. I think that at the moment can not solve this problem, the software update when the battery in the tablet is already so worn out.
    Microsoft should make repair program tablets are experiencing this problem. It is a factory defect, which Microsoft does not want to admit how council. Worse still difficult to identify a defect during the warranty period because of its sudden occurrence after a year of use of the tablet.
