2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-06-22T18:21:27+00:00
    There is no solution. MS made a great machine on many levels but sacrificed good engineering in terms of power. And have been pretty disappointing with their lack of effort to acknowledge or assist). Once you have battery problems, the only way to continue to use the Surface Pro reasonably is to disable the battery driver. The machine must always be plugged in to power (and the docking station power supply does not serve any more) from then on (and ChargeTech makes a very good portable power source for when you can be no where near a power source). Not great but the machine works flawlessly and it really is a superior laptop/tablet when it functions.
    2016-06-22T16:39:49+00:00
    2016-06-22T16:31:15+00:00
