2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-05-09T17:26:26+00:00
    My Surface Pro 3 is experiencing this issue.  I have not even had it 3 years, but obviously it's out of warranty.  The firmware and solutions online don't fix the problem, and I had sent it in for a battery replacement already when it still was in warranty.  Is there another solution for the dead battery aside from sending it in for $450?  I'd expect a $1200+ system to last more than 2.5 years.
    2017-05-08T20:34:19+00:00
    I have the same problem
    We do have a store near us so I took the Surface 3 to the store
    After 2 weeks I got it back and was  told my battery had a mind of it's own
    some times it got up to 90% charged but usually it was 15%.  This was after two days of keeping it plugged in.
    Have you gotten any help?
    ******@aol.com
    2017-04-04T20:20:57+00:00
    Please write a formal email and concerns to the VPs, sales departments from each country that you can find on linkedin.
    Boycott this idiotic company. I am not paying 600 for a battery replacement for the companys fault.
    Mr Satya Nadella CEO
    Email satyan@microsoft.com
    Telephone 425-882-8080
    2017-04-04T20:20:17+00:00
    Please write a formal write and concerns to the VPs, sales departments from each country that you can find on linkedin.
