2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-04-04T20:20:03+00:00
    Please write a formal write and concerns to the VPs, sales departments from each country that you can find on linkedin.
    Boycott this idiotic company. I am not paying 600 for a battery replacement for the companys fault.
    Mr Satya Nadella CEO
    Email satyan@microsoft.com
    Telephone 425-882-8080
    2017-04-04T20:19:26+00:00
    Please write a formal email and concerns to the VPs, sales departments from each country that you can find on linkedin.
    2017-03-29T18:01:56+00:00
    Print everything out or screen shot it. Microsoft is trying to bury their problems and cover their **** for the lawsuit coming real soon
    2017-03-29T17:47:03+00:00
    Where can I find "windows.old"?  I can't seem to find any file or folder by that name.  I, too, am wondering where the older battery report data went.  Luckily, I printed it out.  But it would be nice to know where the older data went, or is stored.  You said here to look in "windows.old" and I can't find any folder or file called windows.old.  Thank you for any help with locating the older battery report data.
