2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-06-28T23:15:44+00:00
    I've finally returned to this forum.
    Anyway, my original SP3 was still under warranty so I was able to get it replaced.  No issues so far with the new one.
    One thing I'm not doing is leaving it plugged in like I did the last one.
    2016-06-28T22:41:31+00:00
    So sorry for you but welcome to the club. We are a very fast growing community.
    2016-06-28T21:14:49+00:00
    Here are my stats. I purchased my SP3 Pro in December 2014, so I am out of warranty. I don't have much interest in paying to swap out for a refurb unit that might develop the same issue, so it seems that I now have a 1.75 pound desktop.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=a4c5563c-7e54-4640-b4d3-de29cf59ea38)
    2016-06-28T14:13:25+00:00
    Obviously, you've not read the forms and all the information online like I have.  Hardware failure and hardware failure in multitudes without the manufacturers acknowledging them are two very different things.
    I had a Mac for work for over two years.
    So you have fun 😏
