2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-06-28T13:53:30+00:00
    My next purchase will be MAC and I won't come back.
    Don't forget to not complain whenever your "MAC" (whatever that is, probably a Mac) develops a fault, because there are no magical pieces of hardware that never fail.
    Bye. Have fun.
    2016-06-28T11:59:32+00:00
    My surface pro 3 is now out of warranty and the battery last about 15 minutes and shuts down.   I tried my best to stick with Windows but it looks like they have made up my mind.  My next purchase will be MAC and I won't come back.
    2016-06-27T18:31:53+00:00
    Hello everybody,
    The battery of my surface pro 3 has problem, It was take only some minutes from 0% to 100% when I charge it. When I unplug power cable, the surface will turn off immediately. I've last update firmware. In the battery report, FULL CHARGE CAPACITY is 350mWh. Pls help me how to fix it?
    2016-06-26T17:51:27+00:00
    My Surface Pro 3 has no battery life. It works fine on the docking station and shows 100% charge, also when charged directly by the power cord and once off the power it dies immediately. The full charge capacity is a paltry 900mwh compared to the deisgn  full charge capacity of 42K ( we ran a battery report) Has any one else experienced this?
    It started losing power about 1 month ago.
    The battery manufacturer is
    X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1161304580
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    Thanks
