2019-08-17T15:39:13+00:00
2019-10-11T17:10:26+00:00
October 10 release
379 additional answers
    2019-08-23T14:31:04+00:00
    Shutting down, while plugged in, at a full charge seems to be the factor for me. Shutting down after being on battery does not seem to cause the issue.
    2019-08-23T06:43:54+00:00
    Have you noticed any drop if you shut off your device at less than 100%?
    For instance, what if you shut it off again after it starts up around 75%, does it then start at 50% next time?
    So far I’m not seeing that happen. Understanding exactly what conditions trigger this issue may help in solving it.
    2019-08-23T06:14:19+00:00
    I am able to confirm the same observation.
    2019-08-23T06:07:02+00:00
    I can confirm that this is not actually an "overnight" problem.
    All I have to do is take my fully charged laptop. Shutdown. Unplug. Wait even 10 minutes and start it up again to find the charge showing around 75%.
