2019-08-17T15:39:13+00:00
2019-10-11T17:10:26+00:00
October 10 release
379 additional answers
    2019-08-22T20:33:58+00:00
    So far, as far as I can tell, the apparent battery drop only happens when the PC is shutdown at 100%. When shut down at lower charge levels it seems to have the same charge when started up again.
    2019-08-22T01:32:47+00:00
    I have the same problem. Brand new Surface Laptop 2.
    2019-08-21T16:45:01+00:00
    Thank you, I appreciate your efforts. In addition to this thread and using the feedback hub, I’ve also reached out to Microsoft Support on Twitter. They quickly replied to me through direct message and guided me through some troubleshooting. They also directed me to the Surface Diagnostic Toolkit. I’m impressed by the concern that they showed and how much they did try to help, but in the end it came down to “get it checked out”.
    So I will weigh my options and consider visiting the MS Store if there are no further developments.
    2019-08-21T16:25:17+00:00
    I’m considering visiting an MS Store, but I’m willing to bet that they will run some standard diagnostics (I’ve already followed troubleshooting guides and used the Surface diagnostic toolkit) and find nothing wrong. It probably won’t be possible to reproduce the problem on the spot, and at best they’ll offer me a refurbished replacement, which is not what I want, and may just end up with the same problem.
    Given that this is most likely a software/firmware problem, the best course of action might just be bringing it to MS’s attention as much as possible and hoping it gets fixed in an update.
