2019-08-17T15:39:13+00:00
2019-10-11T17:10:26+00:00
October 10 release
379 additional answers
    2019-08-24T04:39:14+00:00
    Hey Everyone,
    I posted a possible "fix" on the Surface sub reddit and a couple people have reached out to me and told me it has cured their battery issues.
    Goes a little something like this:
    1. Go into Device Manager -> Battery-> Uninstall the device driver for the the battery itself and the AC Power Adapter
    2. Immediately after uninstalling the drivers, go ahead and turn your PC off. Make sure its turned completly off (no hibernate, no sleep) for up to 10 hours. Recommended you do Steps 1 and 2 before bed
    3. Upon waking up, use your Surface till the battery hits 0%, letting it turn off by itself
    4. Once you charge your Surface up to 100%, click on the battery indicator Icon and flick it from "Battery Saver" to "Recommended"
    5. Done
    This has worked for people experiencing the following problems: "Battery indicator stuck at 100%", "Battery at 70-75% when I turn my PC on"
    2019-08-24T01:20:21+00:00
    I've been informed by Microsoft Support on Twitter that the only way this problem will get attention is if people file reports using the the Feedback Hub app. Please file a report so that something will be done.
    It may also help if you up vote my report, which you should be able to access here: https://aka.ms/AA5w24b
    2019-08-23T22:02:23+00:00
    I also have the same problem. What I noticed is battery dropped to 75% in the morning although I shutdown with full charged.
    2019-08-23T17:12:14+00:00
    I tried to see if I could use this as a work-around. I used my PC plugged in and fully charged, then simply unplugged it a moment before initiating shutdown.
    Didn't work. Charge level said 79% when I powered up just minutes later. Seems like the device must be a least a bit below 100% when you shutdown, plugged in or not, for this issue not to occur.
    My next experiment will be to see how long the PC runs on this "depleted" charge. Seeing as it seems impossible that the battery can actually lose 20-25% charged within minutes of being shutdown, it seems likely that the software is simply reporting the charge incorrectly. If this is the case, it should still last just as long. I'll report my findings.
