Microsoft Surface Pro 6 battery swelling
KJ 0 Reputation points
2026-07-10T18:20:18.8066667+00:00
Microsoft Surface Pro 6 battery is swelling, bowing the glass screen. Please advise. Thank you.
    2026-07-11T00:25:38.56+00:00
    https://support.microsoft.com/en-us/accounts-billing/manage/check-your-microsoft-warranty-and-create-service-orders
    Sign in with the Microsoft account linked to the device.
    Look up the Serial Number— you'll need this to check warranty/service eligibility.
    Choose "Battery swelling / physical damage / safety issue" as the reason if such a category appears — this often gets routed faster than general repair.
    If out of warranty, ask about Microsoft's paperless recycling/safety exchange program
    2026-07-10T18:20:57.13+00:00
    Stop using the Surface Pro 6 immediately and handle it with caution. A visibly swollen battery and bowing screen indicate advanced battery expansion and a potential safety risk.
    Recommended actions:
    1. Stop using and avoid charging the device
      • Power it down and disconnect it from AC power.
      • Do not press on the screen or chassis, and do not attempt to puncture, open, or remove the battery yourself.
    2. Handle and store the device safely
      • Treat it as a damaged battery device.
      • Avoid putting pressure on the swollen area to reduce the risk of puncturing the battery cell.
      • Keep it away from heat sources and flammable materials.
    3. Contact Microsoft for support/replacement
      • For visibly expanded batteries, Microsoft recommends stopping use and working with Surface Support.
      • Complete the appropriate Surface replacement or service request so a Surface Support Advocate can assist with repair/replacement options and safe handling.
    4. If a thermal event occurs (smoke, heat, popping, or hissing)
      • Do not use water to extinguish a battery fire.
      • Smother the device with clean, dry sand, a fire blanket, or a Class B fire extinguisher.
      • Ventilate the area, call local fire authorities if needed, and wait at least two hours before touching the device.
      • Dispose of the device according to local environmental guidelines.
    5. Disposal and recycling
      • Damaged or swollen batteries must be handled as hazardous material. Follow local e‑waste or hazardous waste collection guidance.
      • Each damaged device should be packed individually, enclosed in non-metallic inner packaging (such as a sealed plastic bag), cushioned with non-combustible, non-conductive material, and clearly marked as containing a damaged battery if shipping or handing over for disposal.
    Do not attempt a DIY battery replacement on a swollen Surface Pro 6; use Microsoft service options or qualified professionals only.
  3. Dag Olav Hødnebø 0 Reputation points
    2026-10-07T09:21:57.3333333+00:00
    IMG_0437.jpeg Reeceet for delivery to safe desposel
  4. Dag Olav Hødnebø 0 Reputation points
    2026-10-07T09:18:18.0566667+00:00
    IMG_0407.jpeg. Soling the swallen battery
  5. KJ 0 Reputation points
    2026-07-10T18:23:57.3266667+00:00
    How do I obtain "Microsoft Surface replacement or service request"?
