2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-01-13T11:38:33+00:00
    I was actually able to almost fix my issue!
    I created a flash drive with the media creation tool which now makes build 14393 (the anniversary update) and completely wiped my SP3 and installed a clean Windows on it. It found only 4 updates after that and interestingly enough the November firmware update was again one of them (I've already applied it once before).
    After that I did a test with YouTube nonstop in Chrome and it lasted 4 hours 30 minutes before going to hibernate due to low battery.
    Under normal conditions it shows almost 6 hours on a full charge.
    Still no mAh data in the battery report but maybe it needs more cycles to calibrate...
    2017-01-12T21:28:17+00:00
    i have the same problem. been ringing the support coz i thought it was a problem with the update but seems not! no matter how i update my surface it doesnt solve my problem. weeks ago my battery would last 2 hours. now, barely an hour. just after the warranty expired days ago. will not suggest this product to any friends.
    2017-01-09T15:34:42+00:00
    The only difference I have is that is is stuck "88%, plugged in, not charging". Same exact thing - if you bump magnetic plug, it is like pulling the battery out. Grrrr. Happened only a couple months after warranty expired. Installed the firmware upgrade, upgraded from 8.1 to Windows 10 - nothing. Tried completely wiping/reformatting/restore to factory settings, but now every time I try to do any upgrades, it flashes “Surface” then “Preparing Automatic Repair” then light blue screen of death “:-( your PC ran into a problem and needs to restart. We’re just collecting some error info, and then we’ll restart for you.” Then it cycles back to the black screen “Surface . . . Preparing Automatic Repair” and stays in a loop until hold down power button.
    Finally got it to a point where it will run, but won't update? Wasted hours.
    2017-01-09T07:18:02+00:00
    I have a SP3 with a SIMPLO Battery that has some issues.
    It refuses to charge nor discharge (stuck at 54%, plugged in, not charging) and the Surface doesn't power up without AC connected. If it has AC connected, it starts up, but the moment i take out AC it turns off immediately.
    Does anyone this issue?
