2019-08-17T15:39:13+00:00
2019-10-11T17:10:26+00:00
October 10 release
379 additional answers
  1. Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
    2019-09-27T17:07:19+00:00
    You can post as you wish as long as it meets the community code of conduct. I
    believe that there are several bugs involved. Hopefully someone from Microsoft
    Surface engineering will post something official sooner rather than later to
    help clarify things.
    2019-09-27T16:26:52+00:00
    Keep posting.  Who cares if a moderator disagrees or not.  Most of those are volunteers as well and are not "Microsoft".  Disagreements are part of the discussion.  Sometimes, there are valid arguments with "disagreements" and can bring out something that nobody saw before.
    In fact, that is the purpose of having a discussion!
    Keep posting.
    2019-09-27T16:15:39+00:00
    I don't think we are "off topic" but I also understand that Andrew7783 is concerned: however, it seems to me that we are understanding the reasons for a possible bug and, therefore, I consider the discussion useful. However, if the moderators do not agree, I will not post any more.
    2019-09-27T16:04:04+00:00
    You know Andrew7783, it may all sound a bit confusing but you may have started one of the most important threads out there.  No matter what generation model of Surface tablet or laptop (even Book) model you have, they all have the exact same power management system.  You fix one, you fix all.  The only two machines that are different are the Surface Hub and Surface Studio which are A/C powered only.
    What may be confusing is the RTM and Windows Insider Builds but this is where the experiment of the builds come in handy.  If an experimental firmware update is either built into a build or comes separate in a build and fixes an issue, this is an indicator to Microsoft that they can say "hey, maybe we finally got it" and can test it on an RTM build to see if they get the same result.  If it works, then they can release it to those with RTM machines as a firmware update (can also be buried in an Accumulative Update) and fix everybody's problem.
    I personally think you started the most important thread on the entire forum because power management has been a thorn in the entire Surface series.  This started a discussion and some came up with a 'fix' on their own and got good results but it is actually in Microsoft's court to actually fix the problem.
    I have been on my Surface Laptop (1st gen) right now with Build 18990 and had no power drop overnight and also been on battery for over an hour right now and the battery gauge says 87%.  I never got a battery life like that before and would have been down in the 60s.  This newer firmware update (which was included within the build), seems to be doing the trick.
    Good job on you to start this thread!  A real good discussion is coming out on this.
