2019-08-17T15:39:13+00:00
2019-10-11T17:10:26+00:00
October 10 release
379 additional answers
    2019-09-27T15:44:37+00:00
    ok, I'm going to do this test: now, I have disabled SMT and I let the battery discharged till to 4%, then I recharged it till 100% and I will try such condition for battery improvement.
    Sounds good Jose. Let me know how it goes, when you are ready.
    2019-09-27T15:31:30+00:00
    Very true. This thread was originally created with regards to one specific battery/firmware issue that as far as I know, only ever affected SP6 and SL2 devices, stemming from an August firmware update, and is apparently resolved by firmware currently being distributed via Windows Insider.
    Discussion of other unrelated Surface battery issues affecting other devices has worked its way in here and has at times made the conversation confusing.
    2019-09-27T15:19:12+00:00
    Running an MSI won't install an older version of FIRMWARE. As far as I know, you
    can't uninstall or revert Surface firmware to an older version.
    thanks a lot for your reply!
    I hope in a new update soon!
    2019-09-27T15:18:14+00:00
