Edge Sync broken - is https://edge.microsoft.com down
Andrew Macaulay 186 Reputation points
2026-11-11T08:50:17.9633333+00:00
Edge sync when using a Microsoft Account is broken (including latest update 157.0.4341.46): when you close Edge and then go back in, the Profile Sync state gets stuck in "setting up sync" and never completes this stage and never sync's the data.
If you logoff from the account and then reconnect to the account, the sync gets setup correctly, but again fails the next time you close Edge.
This is an issue that has been happening across multiple machines running Windows 11 and multiple Microsoft accounts for probably around a month now. Not tested with Google or Apple accounts. Note that this issue is not occurring on Edge on Android (current version 157.0.4341.42).
I have done the following steps to try to address this issue (when correctly connected and sync'ing). Most of these I'd done previously, but following AI response, also checked a few other things:
  1. Re-sync data, did not help
  2. Reset sync data from Microsoft servers (have disconnected profile everywhere else), did not help
  3. Checked edge://sync-internals/ and sync is enabled, nothing obvious as error
  4. Checked edge://signin-internals/ and no apparent issues there either
  5. Checked edge://policy/ to confirm no policies stopping sync
Then checked the following endpoints, as suggested by the AI response:
  1. https://edge.microsoft.com which shows error
       <h2>Our services aren't available right now</h2><p>We're working to restore all services as soon as possible. Please check back soon.</p>0mC/0agAAAACaaBKpf8m9TLHwwMctrDZRTE9OMjgxMTgxNzA5MDYwAEVkZ2U=
  2. AI also suggested testing the endpoints for https://.cloudmessaging.edge.microsoft.com and wss://.cloudmessaging.edge.microsoft.com but could not work out what exactly to test for these.
Reported through Edge feedback (multiple times) and also on Feedback Hub https://aka.ms/AA145lq8
Microsoft Edge | Profile, sync, and sign in | Windows 11
  1. Carl-L 24,990 Reputation points Microsoft External Staff Moderator
    2026-11-12T06:45:35.9633333+00:00
    Hello Andrew Macaulay,
    This doesn't seem like a normal syncing issue, before we proceed further, can you please try to sign out and sign back in, capture sync-internals at the time. And then close and restart Edge and compare the sync-internals when the issue appears?
    I'm waiting for your reply.
