Bitlocker Key -- I keep receiving a wrong single use code when trying to get the key
2026-11-06T21:33:26.17+00:00
Hello :)
I'm speaking on behalf of another person that is unable currently to get the recovery Bitlocker key.
We already know which link to follow to get it; however, we are stuck because everytime that we ask for a new single use code (which is sent to the other email linked to the account), the code is always wrong. It may be because we keep asking for new ones, and there might be a slight offset at the rate at which they get sent... Regardless, if there's no solution, we wish he could receive the single use code by phone, but we don't know how to..
Any ideas?
Windows for home | Other | Recovery and backup
    2026-11-06T21:34:00.4+00:00
    If the single-use code keeps failing, the most likely causes in this scenario are repeated requests, delayed delivery, or a temporary verification block.
    Recommended steps:
    1. Stop requesting new codes repeatedly. Excessive or repetitive requests can trigger a temporary block, and delayed emails can make an older code arrive after a newer request.
    2. Wait before trying again. Microsoft guidance says waiting a day can remove a block. If it still fails after 24 hours, wait longer if possible, up to 1 week.
    3. Check Junk/Spam in the mailbox receiving the code. Valid verification emails come from @accountprotection.microsoft.com. Mark that sender as trusted.
    4. Make sure the code is being checked in the correct mailbox. Verification codes can only be sent to the primary alias or another email already added as a sign-in verification method.
    5. Use a privacy/InPrivate window if one Microsoft account is being used to verify another Microsoft account. Sign in to the account requesting the code in one private window, then open a second private window and sign in to the alternate email account to retrieve the code. This avoids automatic sign-out between accounts.
    6. Try another network. Switch between Wi‑Fi and mobile data, or try a different Wi‑Fi network.
    7. Try another verification method already on the account. If another method is listed during sign-in, use that instead.
    8. If access to the current email is no longer reliable, select I don't have any of these during sign-in and follow the prompts to replace the security info.
    About receiving the code by phone:
    • A phone option is only available if a mobile number is already added as a verification method on that Microsoft account.
    • VOIP numbers cannot be used for sign-in or verification codes.
    • If no phone method is already on the account, it cannot be switched to phone at that step unless another working sign-in method is available to update security info.
    Important limitation:
    • Support agents cannot send verification codes or change account details.
    • If sign-in still fails, use the sign-in helper or Contact Support from Microsoft Support.
    • If the BitLocker recovery key ultimately cannot be retrieved, the accepted guidance in similar BitLocker cases is that the only remaining option is a clean Windows reinstall, which erases data on the drive.
  2. Thomas4-N 23,505 Reputation points Microsoft External Staff Moderator
    2026-11-08T08:40:24.1+00:00
    Hello Juan Pablo De La Rosa - Zalamea,
    Before changing the account’s security information, please note that replacing all existing verification methods involves a 30-day wait, so it won’t provide immediate access to the BitLocker key.
    What exact error appears after entering the emailed code? Also, is a phone number offered when you choose another verification method? That will help distinguish a rejected code from a temporary verification block. Please omit any personal details or codes.
