Searching OneDrive using the web interface returns no results
Steve Rochford 0 Reputation points
2026-11-06T19:50:38.0466667+00:00
When I use the web interface to search OneDrive I get no search results but instead get a message "Something went wrong" followed by "Please try again later" and then "Status: 500, Error: Cannot read properties of undefined (reading 'message')"
I get this error when I search for file or folder names I know are present, searching for people that I know have been found in photos or tags which I know are attached to photos.
I've tried this multiple time for the past few days.
Microsoft 365 and Office | OneDrive | For home | Other
  1. Emma1-N 15,005 Reputation points Microsoft External Staff Moderator
    2026-11-07T01:03:36.53+00:00
    Welcome Steve Rochford,
    Thank you for posting on Microsoft Q&A. I'm sorry that search on the OneDrive website keeps showing "Something went wrong" when you look for file names, people or tags you know are there.
    To point you in the right direction, could you tell me:
    • Which browser and version are you using (for example, Microsoft Edge, Chrome or Firefox)? Have you tried another browser or device?
    • Does search fail in every section, such as "My files" and "Photos", or only in one?
    • Do you use a VPN, proxy, or browser extensions like ad blockers, privacy tools or script blockers?
    • Does search work in the OneDrive mobile app, or in File Explorer if you use the OneDrive desktop app?
    Meanwhile, please try these steps in order and test search after each one:
    Step 1: Test in a private window
    • In Microsoft Edge, press Ctrl + Shift + N to open an "InPrivate" window. In Chrome, this is an Incognito window.
    • Go to https://onedrive.live.com, sign in with your personal Microsoft account, and search again.
    • If search works here, a stored cache or an extension is likely the cause. Go on to Steps 2 and 3.
    Step 2: Clear the browser's cookies and cache
    • In Microsoft Edge, go to Settings > Privacy, search, and services > Clear browsing data > Choose what to clear.
    • Set Time range to All time, tick Cookies and other site data and Cached images and files, then select Clear now.
    Step 3: Turn off extensions, VPN and proxy for now
    • In Edge, go to Settings > Extensions > Manage extensions and switch off all extensions, especially ad or script blockers.
    • Disconnect any VPN or proxy, then restart the browser and search again.
    • If search works, turn the extensions back on one at a time to find the one causing the problem.
    Step 4: Sign out and test a simple search
    • On OneDrive, select your profile picture in the top-right corner, then Sign out. Close every browser window, reopen the browser and sign in again.
    • Search for one exact file name with no special characters, then try a tag or a person's name. This shows whether every search fails or only certain types.
    Looking forward to your update.
