Having sound issues with bluetooth MS Edge
MK 40 Reputation points
2026-11-04T08:16:52.1533333+00:00
Just recently my MS Edge stopped transmitting sound to my Bluetooth speakers (Ruark MR1).
I have already checked:
  • Tabs are not muted
  • Rights to transmit sound on Edge is not restricted
  • Speakers are working and transmitting sound. I have tested the same on Chrome and sound is fine
  • Tried to reset settings on Edge
  • Drivers are up to date
Any tips ?
Microsoft Edge | Audio and video playback | Windows 11
SD - IA 183.1K Reputation points Independent Advisor
2026-11-06T12:42:31.16+00:00
Your welcome. Please click Accept Answer if you have no other queries - have a great day!
2026-11-05T06:42:30.1733333+00:00
Alright, please wait for the next release in that case, when the Dev/Beta version moves to production release, which should be the week of 19 November 2026.
I hope this information helps. If you have any more questions, don't hesitate to reach out. Wishing you good luck!
4 additional answers
  1. SD - IA 183.1K Reputation points Independent Advisor
    2026-11-04T12:35:13.3766667+00:00
    Thank you, MK. It clearly means there is a bug in Microsoft Edge production release.
    Can you share a screenshot of this page before coming to a conclusion:
    edge://settings/privacy/sitePermissions/allPermissions/mediaAutoplay
  2. SD - IA 183.1K Reputation points Independent Advisor
    2026-11-04T11:03:59.18+00:00
    Good to be proactive :)
    Here is a URL:
    https://explore.microsoft.com/en-us/edge/download/insider
    I look forward to hearing from you to get the results of the troubleshooting.
  3. SD - IA 183.1K Reputation points Independent Advisor
    2026-11-04T09:28:40.6233333+00:00
    You have done a great amount of troubleshooting.
    Next step: Please go to:
    https://c2rsetup.edog.officeapps.live.com/c2r/downloadEdge.aspx?platform=Default&source=EdgeInsiderPage&Channel=Dev&language=en&Consent=1&brand=M103
    Download and install Edge Dev version. Are you able to repro the issue in the same?
