How do i fix my system wouold not sleep and screen
Baha Habashy 80 Reputation points
2026-10-24T22:51:30.1733333+00:00
I hope you can help me.
Here are the Windows 11 power settings on my HP ZBook Firefly 15 G7. The laptop lid is often down. I reset the defaults on my Samsung S20 D70XE.
I have tried many settings. But nothing seems to work.  I hate to waste so much power and burn my screen
Windows for home | Windows 11 | Sleep and Power on, off
  1. Ferdinand Nanalig 34,115 Reputation points Independent Advisor
    2026-10-25T00:59:22.3733333+00:00
    Hi, let me help you.
    Do you have any third-party devices connected? If you do, remove them and then check if the machine goes to sleep.
    Is your Windows up to date? If not, please update Windows.
    2026-10-24T22:51:45.8633333+00:00
    Try this Windows 11 check list in order:
    1. Set lid close to Sleep
      • Open Search on the taskbar, type control panel, and open it.
      • Go to System and Security > Power Options > Choose what the power buttons do.
      • Select Change settings that are currently unavailable.
      • For When I close the lid, set On battery to Sleep.
      • Set Plugged in to Sleep too if the lid is often closed while connected to power.
      • Select Save changes.
    2. Shorten the screen and sleep timers in Settings
      • Go to Start > Settings > System > Power & battery > Screen and sleep.
      • Set On battery power, turn off my screen after to a shorter time.
      • Set On battery power, put my device to sleep after to a shorter time.
      • If the laptop is usually plugged in, also reduce the Plugged in times.
    3. Use a more efficient power mode
      • Go to Start > Settings > System > Power & battery.
      • Under Power mode, choose a more efficient mode, or Best Power Efficiency if available.
      • This can reduce background activity and power use.
    4. Turn on Energy saver
      • Go to Settings > System > Power & battery > Energy saver.
      • Turn on Lower screen brightness when using energy saver.
    5. Check display settings that affect power use
      • Go to Start > Settings > System > Display > Brightness and lower brightness.
      • Go to System > Display > Advanced display and select a lower refresh rate.
      • If available, enable Dynamic refresh rate.
    6. Run the Power troubleshooter
      • Go to Start > Settings > System > Troubleshoot > Other troubleshooters.
      • Select Run next to Power.
    7. If the PC still refuses to sleep, use a temporary workaround
      • Install PowerToys from the Microsoft Store and use Awake to control sleep behavior while troubleshooting.
    Since the lid is often down, step 1 is the most important. If When I close the lid is set to Do nothing, the laptop can stay awake with the screen behavior controlled separately, which matches the problem described.
