Edge not syncing "Setting up sync"
Jeremiah de Kroon 80 Reputation points
2026-10-13T19:40:57.7666667+00:00
Hi there, I've had a problem with syncing for quite some time. Earlier this year I had a sync problem that went away, it had to do with authentication and tokens. Today it is back now now with network error. It particularly happens on my MS Surface with Win 11 but does not happen on my Dell XPS with Win 10 or iPhone 13. Last week I fixed the problem by installing the stable version after being on 155.0.4283.24 Beta. A week later running 155.0.4283.45 (Official Build) and the sync problem is back. I have tried repairing edge, re-syncing, Verified DNS resolution works correctly: ISP DNS, Cloudflare (1.1.1.1), Google DNS (8.8.8.8).
Authentication generally succeeds:
  • Current auth error: None
  • Token error with: None
  • Has Token: true
Typical startup sequence:
  • Try to start sync engine
  • Load and connect Nigori controller
  • ConfigureSyncer
  • Configured DataTypeManager: Ok
  • DoStartSyncing
Initial sync requests succeed:
  • Initial GetUpdates
  • Reason: NEW_CLIENT
Server response:
  • "error_code": "SUCCESS"
Over time the logs repeatedly show intermittent failures:
  • ERR_NAME_NOT_RESOLVED
  • ERR_INTERNET_DISCONNECTED
  • ERR_CONNECTION_RESET
  • ERR_ABORTED
  • HTTP error (401)
Current encryption state appears healthy:
  • Has Keystore Key: true
  • Cryptographer Has Pending Keys: false
  • Cryptographer Ready To Encrypt: true
  • Passphrase Type: kKeystorePassphrase
This suggests the issue is no longer related to missing encryption keys.
I am out of ways to fix this and it is unsustainable to delete the profile once a day or reinstall edge regularly.
Microsoft Edge | Profile, sync, and sign in | Windows 11
  1. Martin Wallenböck 45 Reputation points
    2026-11-09T10:17:38.6133333+00:00
    Yes, it’s sad. Microsoft is completely isolated and has no interest in its customers or their needs.
    I’m not sure if they’ve even realized that it’s well past the eleventh hour—given that AI is now capable of replicating everything... without any errors.
  2. Steve Goncalves 0 Reputation points
    2026-11-09T20:08:34.1666667+00:00
    Also stuck on 'Setting Up Sync' on 3 different Windows machines with Edge. My Android Edge, however is syncing. Would be great to get this fixed soon. Huge issue. Thanks
