Edge not syncing "Setting up sync"
Jeremiah de Kroon 80 Reputation points
2026-10-13T19:40:57.7666667+00:00
Hi there, I've had a problem with syncing for quite some time. Earlier this year I had a sync problem that went away, it had to do with authentication and tokens. Today it is back now now with network error. It particularly happens on my MS Surface with Win 11 but does not happen on my Dell XPS with Win 10 or iPhone 13. Last week I fixed the problem by installing the stable version after being on 155.0.4283.24 Beta. A week later running 155.0.4283.45 (Official Build) and the sync problem is back. I have tried repairing edge, re-syncing, Verified DNS resolution works correctly: ISP DNS, Cloudflare (1.1.1.1), Google DNS (8.8.8.8).
Authentication generally succeeds:
  • Current auth error: None
  • Token error with: None
  • Has Token: true
Typical startup sequence:
  • Try to start sync engine
  • Load and connect Nigori controller
  • ConfigureSyncer
  • Configured DataTypeManager: Ok
  • DoStartSyncing
Initial sync requests succeed:
  • Initial GetUpdates
  • Reason: NEW_CLIENT
Server response:
  • "error_code": "SUCCESS"
Over time the logs repeatedly show intermittent failures:
  • ERR_NAME_NOT_RESOLVED
  • ERR_INTERNET_DISCONNECTED
  • ERR_CONNECTION_RESET
  • ERR_ABORTED
  • HTTP error (401)
Current encryption state appears healthy:
  • Has Keystore Key: true
  • Cryptographer Has Pending Keys: false
  • Cryptographer Ready To Encrypt: true
  • Passphrase Type: kKeystorePassphrase
This suggests the issue is no longer related to missing encryption keys.
I am out of ways to fix this and it is unsustainable to delete the profile once a day or reinstall edge regularly.
Microsoft Edge | Profile, sync, and sign in | Windows 11
  1. Park 10 Reputation points
    2026-11-05T10:20:29.2166667+00:00
    Same issue here on Edge Stable 156.0.4314.58 (Windows 11, personal Microsoft account). After every restart, edge://sync-internals showed “Download Key Result: Fail” and “BlockReason: NotStarted”; signing out and back in worked only until the next restart.
    I installed Edge Beta 158.0.4370.1 (released Nov 4) and signed in with the same account. Sync now survives restarts: after closing and reopening Edge several times, “Download Key Result” stays “Success” and sync stays on. So the fix seems to be in the 158 branch. According to the official release schedule, Edge 158 Stable is planned for the week of Nov 19.
    Note: I’m not a native English speaker, so I drafted this with help from Claude (Anthropic). The test results and sync-internals observations are my own, and I checked the final text before posting. The Edge 158 Stable timing comes from Microsoft’s official Edge release schedule: https://learn.microsoft.com/en-us/deployedge/microsoft-edge-release-schedule
    8 people found this answer helpful.
  2. Kirill Kotlyarenko 0 Reputation points
    2026-11-05T18:34:35.17+00:00
    Same problem. Tried same steps as outlined before to rule out any problems on my end. Clearly a bug in v156 build. Please, fix asap.
  3. Randy D 0 Reputation points
    2026-11-07T02:13:24.6233333+00:00
    Same here.Stuck in "Setting up Sync".
  4. Andre' Melancia 56 Reputation points
    2026-11-07T17:51:12.9333333+00:00
    Same problem here:
    • On and off since april 2026, seems to have started when they changed sync methods and started to use workspaces v2;
    • Only with MSA account, 365 accounts work fine (now);
    • Multiple computers share/sync the profile;
    Tried everything, and I see people on this page tried the same things.
    • Only way to solve it is to SIGN OUT, and then SIGN IN again, but...
    • Workspace data (and much more) is lost when you do that (a LOT is lost, especially considering multiple computers are used and difficult to recover, taking hours of manual work to list every single tab opened);
    It was bad enough that the workspaces transition killed half the tabs most people had (MSA and 365), and left us without them for 2 months, but now, after more than 6 months, MSA accounts still have that problem, which everyone wold expect this to be fixed by now.
    THIS IS A PRODUCTIVITY KILLER.
    [EDIT 20261109]
    I just saw an Update button on Edge. I confirmed that my MSA profile has sync on, as well as 365 profiles also sync on. After returning from the Edge update, MSA profile didn't sync, 365 profiles were ok.
    I hope this doesn't mean that every update (currently happening almost twice a week), or every reboot will cause sync to fail.
    After update today, my version is (go to edge://version ):
    Microsoft Edge 157.0.4341.42 (Official build) (64-bit)
    Chromium version 157.0.8103.39
    Operating system Windows 11 Version 26H2 (Build 26300.9711)
    6 people found this answer helpful.
  5. Chen Keng Wee 0 Reputation points
    2026-11-09T10:12:50.7633333+00:00
    Devs are sleeping, encountered this issue quite some time, updates upon updates and is not yet fixed.
