I want to give my surface pro to my teenager how can I remove all of my stuff
Dotti Santomarco 0 Reputation points
2026-10-08T15:10:42.3833333+00:00
I had been using my surface pro for work. I no loner need it so I want to give it to my teenage for school but I want to remove all of my info so he can have a fresh start how do I do that?
    2026-10-08T15:11:00.87+00:00
    To give the Surface Pro a clean start, back up anything needed first, then reset the device and remove it from the Microsoft account.
    1. Back up important data.
      • If Outlook is used, back up Outlook data files before resetting.
    2. Reset the Surface and remove personal data.
      • On Windows 11: Start > Settings > System > Recovery > Reset this PC > Reset PC > Erase everything.
      • On Windows 10: Start > Settings > Update & Security > Recovery > under Reset this PC, select Get started > Erase everything.
    3. If planning to give the device to someone else, use the option that removes everything. On Surface, this reinstalls Windows and removes personal files, settings changes, apps, and drivers that were installed.
      • For Windows 10, when prompted, choose to fully clean the drive to make it harder for other people to recover removed files. This can take 1–2 hours.
      • Cloud download is recommended when offered, and the device should be connected to the internet.
    4. If Windows cannot start, use Microsoft Surface Data Eraser.
      • This boots from a USB drive and securely wipes all data from a compatible Surface device.
      • Warning: this deletes all data on the device, including the operating system, installed apps, files, and settings.
      • The legacy Surface Data Eraser is not compatible with the latest Surface devices including Surface Pro 10 and Surface Pro 11th Edition. For those devices, use Surface Data Eraser (IT Toolkit).
    5. After the reset is complete, remove the device from the Microsoft account.
      • Sign in at https://account.microsoft.com/devices.
      • Find the device, select Show details > More actions > Remove.
      • To stop it affecting the Microsoft Store device limit, select Unlink for that device.
    This process removes personal content from the Surface while keeping the Microsoft account available for use on other devices.
  2. S.Sengupta 33,256 Reputation points MVP Volunteer Moderator
    2026-10-08T15:20:18.6566667+00:00
    Before you reset
    Back up anything you want to keep.
    Sign out of services you use for work, such as Microsoft 365/Office, OneDrive, your browser (to stop syncing), and any other apps tied to your accounts.
    Remove the device from your Microsoft account. Go to account.microsoft.com/devices, find this Surface, and choose to remove it. This also turns off "Find my device" for you.
    Turn off BitLocker/Device encryption only if needed. Usually you can skip this, as the reset handles it. Make sure you have your Microsoft account password in case it asks for recovery details.
    Plug the device into power, because the reset can take a while.
    Resetting Windows
    Open Settings > System > Recovery (on Windows 11) or Settings > Update & Security > Recovery (on Windows 10).
    Under "Reset this PC," click Reset PC (or "Get started").
    Choose Remove everything.
    Choose Local reinstall (quicker and works without internet) or Cloud download (downloads a fresh copy of Windows, useful if the system has had problems).
    On the "Additional settings" screen, make sure Clean data is turned on (it might say "Change settings" first). This overwrites the drive so your old files can't easily be recovered. It takes longer, but it's the right choice when passing a device to someone else.
    Confirm and let it run. The Surface will restart several times.
    When the setup screen appears, your son can sign in with his own Microsoft account
