Problem with 8/28/26 Update
Romney Corder 0 Reputation points
2026-09-10T14:29:50.7666667+00:00
After automatic 8/28/26 update occurred the following problems are happening:
  1. If computer is restarted everything resets and I must reinstall everything
  2. Unable to sync to OneDrive for Work
  3. All files are saved to Temp and I am unable to save anywhere else.
  4. I tried to "uninstall" the update but this particular update does not even show up on the list of updates
Please help, I am losing my mind and am unable to work efficiently.
Thank you,
Romney Corder
Microsoft 365 and Office | OneDrive | For business | Windows
  1. Kien 980 Reputation points Independent Advisor
    2026-09-10T15:25:08.7233333+00:00
    Dear @Romney Corder,
    Before investigating further, could you please help me with a few checks?
    1/ Is this your personal device, a company-managed device, or a shared computer?
    2/ Please try reinstalling OneDrive and let me know if the sync issue persists afterward:
    • Uninstall OneDrive
    • Restart the computer
    • Install the latest version of OneDrive
    • Sign in again and test synchronization
    3/ Please check whether Windows is fully up to date:
    • Go to Settings > Windows Update
    • Select Check for updates
    • Install any available updates and restart the device
    4/ What version of Windows are you currently running?
    • Press Windows + R
    • Type winver
    5/ Is the issue affecting only OneDrive, or do you also notice that files, settings, or applications reset after every restart?
    The answers above will help me understand better about your situation.
    Looking forward to your update.
