How to fix hp Probook laptop with BitLocker Key?
Elsa Yosief Desta 0 Reputation points
2026-09-09T19:51:37.5466667+00:00
My laptop- ProBook get problem with BitLocker Key shows on the screen and no alternative to log in the laptop , what can i do to resolve this problem?
Windows for business | Windows Client for IT Pros | Devices and deployment | Recovery key
    2026-09-09T19:51:54.5+00:00
    If the laptop is showing the BitLocker recovery screen, the supported way to start Windows is to enter the 48-digit BitLocker recovery key. If the key is correct, Windows starts normally.
    What to do:
    1. Enter the recovery key on the BitLocker screen
      • Hyphens are optional.
      • If accepted, the device boots into Windows.
    2. Check where the recovery key may be stored
      • Microsoft Entra ID: if the device is managed by work or school, sign in to https://myaccount.microsoft.com, open Devices, select the Windows device, and choose View BitLocker Keys.
      • It may also have been saved to a USB device, printed, or stored in AD DS.
    3. If the recovery screen shows a Secure Boot error
      • For E_FVE_SECUREBOOT_DISABLED, re-enable Secure Boot in firmware/BIOS and reboot. This might stop the recovery prompt.
      • For E_FVE_SECUREBOOT_CHANGED, a recovery method is required to unlock the device.
    4. If the device is locked out after too many PIN attempts
      • Use the recovery key.
      • Or wait for the unlock period to expire and then enter the correct PIN.
      • From the BitLocker entry screen, pressing Esc can expose other recovery options, including Command Prompt. From there, manage-bde can unlock the drive or turn off BitLocker. Warning: turning off BitLocker or changing drive protection affects disk security and should only be done if the recovery key is available.
    5. If Windows still does not boot after recovery attempts
      • Windows RE may start automatically after two boot failures.
      • If Windows RE is started manually, the BitLocker recovery key is required to unlock the drive.
      • If the drive is severely damaged and normal recovery does not work, repair-bde.exe can be used to recover data from a BitLocker-encrypted drive. Warning: this is an advanced recovery tool intended for damaged drives, and other repair options in Windows RE should be tried first.
    6. If the recovery key cannot be found
      • The drive cannot be unlocked without the correct recovery key.
      • If no recovery key is available, the remaining option is typically to reset or reinstall Windows, which causes data loss.
  2. Harry Phan 30,640 Reputation points Independent Advisor
    2026-09-10T00:16:44.15+00:00
    Hello Elsa,
    When your HP ProBook is showing the BitLocker recovery screen, it means the system drive is encrypted and Windows is asking for the recovery key before it can boot. There is no way to bypass this prompt; you must supply the correct BitLocker Recovery Key.
    The recovery key is automatically saved when BitLocker was first enabled. Common places to check are:
    Your Microsoft account at https://account.microsoft.com/devices -sign in with the same account you used on the laptop and look under “BitLocker recovery keys.”
    If the laptop is joined to an organization domain or Azure AD, the recovery key may be stored in Active Directory or Azure AD. In that case, contact your IT administrator.
    If you printed or saved the key during setup, check USB drives, printed documents, or cloud storage where you may have stored it.
    On some HP devices, if BitLocker was enabled by default, the recovery key is still tied to the Microsoft account used during initial setup.
    If you cannot locate the recovery key in any of these places, unfortunately the encrypted drive cannot be unlocked. Microsoft does not provide any supported method to bypass BitLocker encryption without the recovery key. The only option then is to reinstall Windows, which will erase all data on the drive.
    To reinstall, boot from a Windows 11 installation USB, choose “Custom Install,” delete the encrypted partitions, and proceed with a clean installation. Make sure to back up any data you can access before doing this, though in most cases without the recovery key the data is not recoverable.
    I hope you've found something useful here. If it helps you get more insight into the issue, it's appreciated to accept the answer. Should you have more questions, feel free to leave a message. Have a nice day!HP.
