If the BitLocker recovery key is no longer available from the school account, there is no way to retrieve, recreate, or bypass it. Microsoft Support also can’t retrieve or recreate a lost BitLocker recovery key.
What can still be checked:
- Check whether the key was backed up anywhere else when BitLocker was enabled:
- a Microsoft account
- a printed copy
- a text file backup
- a USB device used to store the recovery key
- If the device was managed by the educational institution, ask them to search by:
- device name
- recovery key ID shown on the BitLocker screen
- If recovery keys were stored in Microsoft Entra ID and the account still had access, they would normally be available from
https://myaccount.microsoft.comunder Devices > View BitLocker Keys. If the student account was deleted and the institution confirms the key is no longer available, that recovery path is no longer usable. - If the issue started after firmware or boot-related changes, the device still requires the correct 48-digit recovery password shown for that exact recovery key ID. A nonmatching key cannot unlock the drive.
Important:
- The BitLocker recovery password is a 48-digit number.
- The recovery key ID shown on the recovery screen is only used to identify the correct key.
- If the key ID does not match the stored key, that key will not unlock the device.
If the correct recovery key cannot be found, access to the encrypted data cannot be restored. The remaining option is to reset or reinstall Windows, which removes the encryption but causes data loss.
- Back Up Your BitLocker Recovery Key
- BitLocker recovery process
- BitLocker recovery overview
- How do I find the BitLocker Recovery Key when the Recovery Key ID doesn't match the numbers in my account except for the Key ID? - Microsoft Q&A
- The BitLocker key retrieved by Microsoft is unusable. - Microsoft Q&A
