How can I get a fix for endless boot loop for my new HP Omnibook laptop with Windows 11?
Thomas J Young 0 Reputation points
2026-08-26T15:30:31.6333333+00:00
I cannot boot my laptop. How can I get a fix for endless boot loop for my new HP Omnibook laptop with Windows 11?
Windows for home | Windows 11 | Sleep and Power on, off
    2026-08-26T15:30:49.5733333+00:00
    Try Windows Recovery Environment first, then use installation media if the built-in recovery tools do not work.
    1. Start Startup Repair.
      • Boot into the Windows Recovery Environment.
      • Go to Troubleshoot > Advanced options > Startup Repair.
      • This is the standard repair path for Windows 11 startup problems.
    2. If the PC still loops, try the basic stop-code troubleshooting steps from recovery or Safe Mode if it becomes available:
      • Remove any newly connected hardware.
      • Check Device Manager for problem devices and update, disable, or uninstall the affected device.
      • Make sure the drive has enough free space; 10% to 15% free space is a good target.
      • Install the latest Windows updates when the system becomes bootable.
      • If needed, use a system restore point or another recovery option.
    3. If recovery options on the laptop fail, create a bootable Windows 11 USB on another working PC.
      • Use an empty USB drive with at least 8 GB.
      • Boot the HP laptop from that USB.
      • On the Windows setup screen, select Repair your computer instead of installing Windows.
      • This opens the Recovery Environment from the USB, where Startup Repair and other recovery options can be tried again.
    4. If personal files must be protected before more repair attempts:
      • In the Recovery Environment, open Command Prompt.
      • Run notepad.exe.
      • In Notepad, use File > Open to access the file dialog and copy important files to a USB drive before continuing.
    5. If the issue started after adding another Windows installation and one OS is missing from the boot menu, rebuild the boot entry.
      • Open Command Prompt as administrator or use Command Prompt from installation media.
      • Run:
             Bcdboot D:\Windows
      • Replace D:\Windows with the actual path to the Windows installation.
      • If the drive letter is unknown, run diskpart and then list volume to identify it.
      • Warning: use the correct Windows path to avoid repairing the wrong installation.
    If the laptop is simply stuck in an automatic repair or BSOD loop and none of the built-in recovery options work, the most direct supported path in the provided guidance is to boot from Windows 11 installation media and use Repair your computer from there.
  2. David-M 125.2K Reputation points Independent Advisor
    2026-08-26T16:04:05.57+00:00
    Hi. I'm David, and I'm happy to help you.
    Repair the Windows startup by following the steps below.
    You will need to access the Windows Recovery Environment (WinRE). In your case, to do this, you will repeatedly turn your device off and then on:
    1. Hold down the power button for 10 seconds to turn off your device (If the device is ON when starting the procedure);
    2. Press the power button again to turn on your device;
    3. On the first sign that Windows has started (for example, some devices display the manufacturer's logo with spinning dots when starting), hold down the power button for 10 seconds to turn off your device;
    4. Press the power button again to turn on your device;
    5. When Windows starts, hold down the power button for 10 seconds to turn off your device;
    6. Press the power button again to turn on your device. Windows should display the "Automatic Repair" screen.
    7. Then, select "Advanced options" to enter WinRE.
    Article used as a reference for this procedure: https://support.microsoft.com/en-us/windows/windows-recovery-environment-0eb14733-6301-41cb-8d26-06a12b42770b
    • On the Choose an option screen, select "Troubleshoot > Advanced options > Startup Repair / Quick machine recovery".
    If it persists, use System Restore to restore Windows to a previous working state by choosing a restore point created before the problem started.
    Start your computer again in the Windows Recovery Environment (WinRE).
    • On the Choose an option screen, select "Troubleshoot > Advanced options > System Restore" and follow the on-screen instructions.
    If you don't have restore points, try starting Windows in Safe Mode with Networking.
    • On the Choose an option screen, select "Troubleshoot > Advanced options > Startup Settings > Restart";
    • After your device restarts, you'll see a list of options. Press 5 or F5 to start Windows in Safe Mode with Networking.
    When starting Windows in Safe Mode, I suggest that you make a backup of your data.
    Open Device Manager and make sure all drivers are up to date.
    Then restart your PC and see if it starts normally.
    If the problem persists, please let me know, and I will provide another method.
    Feel free to ask any questions you may have.
