How do I fix
Mary M 0 Reputation points
2026-08-23T17:28:16.0933333+00:00
Task Host is stopping background tasks (Microsoft\Windows\DeviceDirectoryClient\RegisterUserDevice)
Windows for home | Windows 11 | Sleep and Power on, off
  1. Ferdinand Nanalig 32,835 Reputation points Independent Advisor
    2026-08-23T19:45:45.72+00:00
    Hi! Let me help you.
    Have you tried a hard reset?
    Turn off the laptop.
    Unplug the charger.
    Remove all USB devices.
    If the battery is removable → remove the battery.
    Press and hold the Power button for 30–60 seconds.
    Reinsert the battery (if removed).
    Plug in the charger.
    Turn the laptop on.
