A video editing tool developed by Microsoft, designed to make video creation easy and accessible for everyone.
Try the web version: https://app.clipchamp.com
If the web version works, the issue is likely with the desktop app.
You can also try resetting the app:
Settings → Apps → Installed Apps → Clipchamp → Advanced Options
- Select Repair first.
- If that doesn't work, select Reset.
