How to prevent excessive cpu throttling on Surface Pro 7
Ben Carlson 120 Reputation points
2026-01-02T18:27:05.2466667+00:00
When my MS Surface Pro 7 was running Windows 10 Pro, I found the workaround for excessive CPU throttling while working on battery by disabling the "Intel Dynamic Tuning Service" (esifsvc).
This workaround doesn't seem to work with Windows 11 Pro, making my Surface Pro 7 unacceptably slow when working on battery, regardless of the Power mode chosen (Recommended, Better perf or Best perf.)
What is the solution ?
Moderator note: Changed tags and moved thread from [Windows for home › Windows 11 › Performance and system failures]
Surface | Surface Pro | Performance and maintenance
  1. Ben Carlson 120 Reputation points
    2026-02-10T10:05:55.8166667+00:00
    Hi @Lychee-Ng
    I carefully folled all the steps in your post.
    Unfortunately, this does not fix the problem.
    Each time the system is started on battery from a complete shutdown, the CPU GHz is excessively capped; restarting usually helps (system is then "usable" but not sure the optimal perf is reached, the CPU seems to be limited below 2 GHz, far below the wall-powered perf (3,3 GHz or more depending on the load)).
    This is not acceptable behaviour for a tablet format PC.
    I doubt a hardware fault could cause this (the system worked fine, even on battery, with Win10 as long as "Intel Dynamic Tuning Service" (esifsvc) was disabled - strange coincidence that a hardware issue would have been triggered by fresh installation of Win11)
    I'll need to investigate other alternatives (give up with this S7Pro)
  2. Lychee-Ng 28,125 Reputation points Microsoft External Staff Moderator
    2026-02-10T11:54:09.3233333+00:00
    Hi Ben Carlson, thanks for the follow‑up, and I’m really sorry to hear that none of the steps made a difference.
    I have to agree, at this point there isn’t much left you can adjust from the user side. Surface‑class devices rely heavily on DPTF and Modern Standby, and if those drivers seem to not working properly, options become limited.
    I completely understand if you’re feeling worn out with continuing on fixing this S7 Pro, as you’ve already covered everything possible. Since all recommended steps have been performed, I don't think this is caused by anything you missed.
    It's really unfortunate, and I wish I could provide more help with this.
