How to prevent excessive cpu throttling on Surface Pro 7
Ben Carlson 120 Reputation points
2026-01-02T18:27:05.2466667+00:00
When my MS Surface Pro 7 was running Windows 10 Pro, I found the workaround for excessive CPU throttling while working on battery by disabling the "Intel Dynamic Tuning Service" (esifsvc).
This workaround doesn't seem to work with Windows 11 Pro, making my Surface Pro 7 unacceptably slow when working on battery, regardless of the Power mode chosen (Recommended, Better perf or Best perf.)
What is the solution ?
Moderator note: Changed tags and moved thread from [Windows for home › Windows 11 › Performance and system failures]
Surface | Surface Pro | Performance and maintenance
  1. S.Sengupta 32,111 Reputation points MVP Volunteer Moderator
    2026-01-03T01:27:45.75+00:00
    Install Intel Graphics Command Center from the Microsoft Store
    Check the power settings there - sometimes Intel's own software overrides Windows settings
    Download ThrottleStop
    Disable "BD PROCHOT" - this prevents the system from throttling based on battery discharge rates
  2. Ben Carlson 120 Reputation points
    2026-01-03T09:58:02.8333333+00:00
    Now I realize that I went through this sequence, as I already installed Intel Graphics Command Center:
    • Clean install W11
    • At some point I notice slow perf on battery
    • disable "esifsvc"
    • Perf on battery back to normal :-D
    • Install Intel Graphics Command Center
    • Noticed perf awfully slow again (CPU speed tops around 0.6 GHz, changing the Power Mode doesn't change much)
    • Uninstalling IGCC, toggling esifsvc, nothing now allows normal performance on battery again.
    Of course, no rogue background task etc.... and running on external power gives the expected perf (CPU between 1.50 and 3.00 GHz depending on the load)
    I'll give ThrottleStop a try (and report here), but I'm really angry that I need to use a "hack" to get "normal" performance on the Surface 7 - and wonder why simply disabling esifsvc no longer helps in Win11 like it did in Win10. I was really pleased with that system and would really avoid to buy something new (as it performs now, this 8 core i7-1065G7 is unusable on battery, even simple things like email & Internet browsing are frustrating, even with Copilot & other AI things disabled)
  3. Ben Carlson 120 Reputation points
    2026-01-07T10:24:36.4433333+00:00
    Problem is actually NOT solved.
    It turns out that the fixes in my latest comment are not permanent.
    When in battery mode, the CPU throttling (and probably also RAM & busses etc.) is unpredictable: sometimes the CPU caps at about 0.6 GHz regardless of the Power Mode making the unit excruciatingly slow (unusable), even for simple tasks, sometimes it works as expected with reasonable dynamic CPU throttling and no hard GHz ceiling.
    I had also at least one occurrence where this happened with the unit on external power !
    The worst is that it looks so random, no matter what I try: restart Win11, shutdown then cold boot, turn on/off Fast Start, nudge the Power Mode or the Power Plan.
    At this point, my Surface Pro 7 is unusable as portable device (which is why I bought a system with this form factor in the first place!). I reckon there must be a flaw in the BIOS and/or Intel system device drivers that Win11 (even pristine installation) made just worse (as I said earlier, the problem was there initially when I purchased the computer with Win10, but the fix was quite simple and effective: disable the "esifsvc" service) and I guess there's not update to be expected, considering the commercial lifespan of a Surface Pro 7.
    Suggestions welcome before I throw it through the window.
  4. Ben Carlson 120 Reputation points
    2026-01-24T14:43:15.0066667+00:00
    The problem is hard to tackle as it is quite random:
    When I shutdown when plugged in then power on while on battery (Fast start-up enabled or disabled), I see the CPU limited to about 0.6 GHz; when I then Restart a few times, it gradually gets better, i.e. the ceiling GHz seems to increase at each restart !!!! But then, when I put the S7Pro to hibernation and later wake it up, it's back to 0.6 GHz.
    It looks like shutdown/boot or restart carries some (unwanted) power state data over. Is that possible ? Anyway this makes Windows 11 on this S7 Pro unusable. I reckon using third-party apps or some hacks as workaround just to make the S7Pro predictably usable on battery under W11 is unacceptable.
    Are there still Surface Pro 7 users out there ? Happy with W11 on it ?
    I can't imagine I'm the only one to face this extreme slowness on battery (and don't see why since I have installed W11 from scratch)
    Any help appreciated...switching to Linux or bying a new system are currently my only options :-(
    FWIW, I had a S4Pro that exhibited a firmware bug reported by some, that would drain the battery in a few days, even when in hibernate or complete shutdown mode. Then this S7Pro excessive CPU throttling issue....My wife had a S3Pro that is still working like a charm, even the battery reports over 100% of its initial usable capacity !!!!! Unfortunalety locked to W10, it still serves (offline) for a few legacy hardware devices that W11 won't recognize...If I eventually opt to change for a new ultraportable, it won't be a MS Surface anymore.
  5. Lychee-Ng 28,125 Reputation points Microsoft External Staff Moderator
    2026-02-04T10:31:47.6+00:00
    Hi Ben Carlson,
    Welcome to Microsoft Q&A! And thanks for the very detailed breakdown.
    I know how frustrating it is when a Surface Pro 7 becomes stuck at 0.6 GHz on battery and essentially unusable. This behavior is often caused by the Surface firmware or Intel Dynamic Tuning getting stuck in a low‑power state after upgrading to Windows 11. Although not guaranteed to work 100%, below are some solutions that have helped other SP7 users that you can try out:
    1 - Fully reset the embedded controller (EC)
    • Unplug everything: charger, mouse, headset, USB, and so on.
    • Hold Shift > select Shut down and keep holding Shift.
    • After the screen turns off, wait for at least a minute.
    • Then, press the power button for 20-30 seconds:
    • The Windows logo will appear, disappear, and then appear again.
      • Make sure that sequence is complete > let it turn on on battery.
    2 - Install all available Surface firmware updates
    • Plug the charger to a wall socket, confirm energy is stable.
    • Go to Settings > Windows Update > Check for updates
    • Also check Advanced options > Optional updates
    • Install everything under Surface, System, or Firmware
    • Restart your Surface following the steps instructed above.
    3 - Reset Windows power schemes
    • Press Win + X > choose Terminal (Admin) to open Windows PowerShell
    • Run: powercfg -restoredefaultschemes > When it's done, restart your PC.
    4 - Disable Modern Standby temporarily
    • Open Windows PowerShell (Admin) as described above.
    • Run the following commands one by one:
      • powercfg /h off
      • reg add "HKLM\System\CurrentControlSet\Control\Power" /v PlatformAoAcOverride /t REG_DWORD /d 0 /f
    • Restart and if performance now stabilizes, Modern Standby is the trigger.
    If none of the above restores stable performance, it likely points to a hardware fault, and replacement might be the only practical option, unfortunately.
