Edge Mobile does not sync tabs
Tareq Hijazi 0 Reputation points
2025-10-05T06:09:41.66+00:00
Edge Mobile (Android, Samsung Galaxy Fold 7), does not show Tabs from other devices although Sync is on and sync open tabs is set to ON, I have other Windows PCs and from Edge Desktop I can see Tabs from other devices, including Tabs open on my Android mobile.
Microsoft Edge | Tabs, address bar, and search | Android
  1. paulr0511 49,755 Reputation points Independent Advisor
    2025-10-11T14:22:09.08+00:00
    The other thing that you can check and test is by creating and doing this on another or different profile and this is to rule out if this is an issue with your profile or not and refer to the link below as well.
    https://support.microsoft.com/en-us/topic/sign-in-and-create-multiple-profiles-in-microsoft-edge-df94e622-2061-49ae-ad1d-6f0e43ce6435
