new battery and battery report issue
Bora Bilgiç 20 Reputation points
2025-08-17T01:19:20.6733333+00:00
I made my battery changed but once I checked battery report cycle count is 137 and full charge capasity 35.350mWh. I asked my technical point why I have these results with a original brand new battery (at least I paid for that) they replied me that it is impossible to reset battery report so you see your battery results as your previous battery. İs it possible? it is impossible to reset it. Or once you put a new battery it shows (battery report) new battery data? which means they put a used battery. Best Regards Bora
2025-08-17T14:07:31.47+00:00
Hi Bora,
When a new battery is installed in a Surface device, the Windows battery report reflects the new battery’s internal data, not the old one. This includes the cycle count and full charge capacity, which are stored in the battery’s firmware. If the report shows a cycle count of 137 and a low capacity, it means the battery is used. The claim that the report shows old battery data is incorrect, it always reflects the current battery’s stats. Hope this answers your confusion.
Best,
Jeric
