Word for Mac link problem when saving PDF using Macro
2018-03-02T17:07:39+00:00
Please note: this question is regarding a problem in Word for Mac 2016, and NOT Word for Windows. I only refer to the Windows version to provide a contrast and demonstrate the problem. Thanks.
I'm experience problems with links not working when Word for Mac 2016 documents are saved as pdf using the following macro:
Sub SaveActiveDocAsPDF()
On Error Resume Next
Dim saveName As String
Application.DisplayAlerts = False
saveName = ActiveDocument.FullName
saveName = Left(saveName, Len(saveName) - 5) & ".pdf"
ActiveDocument.SaveAs FileName:=saveName, _
FileFormat:=wdFormatPDF
Application.DisplayAlerts = True
End Sub
To demonstrate I've provided the following Word documents saved at this OneDrive folder:
https://1drv.ms/f/s!AiuBf\_pQqHG\_gpFIcWDjzPvoHsYf6Q
example Word for Mac version 16.10.docx
example Word for Mac version 16.10.pdf
example using Word for Windows 2016  version 1708.docx
example using Word for Windows 2016  version 1708.pdf
When the macro is run using the Mac version the link is not active, but when it is run using the Windows version, the link is active. If you test the files above, the link within does not work in the Mac version pdf, but does work in the Windows version pdf.
I'm using a Macbook Pro with updated OS and updated Office 365 Home software on both Mac and Windows versions.
Thanks,
Microsoft 365 and Office | Word | For home | Windows
    2018-03-06T06:57:29+00:00
    What I wrote was "I did try using the .SaveAs2 method, but it made no difference." In other words, I was trying to implement the suggested solution and it did not make any difference in terms of my problem.  That is, if one modifies the macro I originally presented so that ".SaveAs" is replaced with ".SaveAs2" there is no difference regarding the problem I'm having.
    I'm not sure how to clarify the problem I'm having better than I did in the original post: "I'm experience problems with links not working when Word for Mac 2016 documents are saved as pdf using the following macro:"
    Then, in my post on March 5, I respond to others who had suggested that I focus on  the option buttons presented during a manual save. In one sense, that suggestion does not address my original question, which has to do with macros rather than manual saves. But on the other hand, I am saying that I've learned that the option choice one makes during the manual save affects subsequent behavior of the macro.
    Then, in that same post, I express puzzlement over this whole situation.  I mean, I just want a macro that will save a document as pdf with one click and have the links still work. But no matter what I do, I can't achieve that.  Instead, what I can achieve is a macro which will result in that desired behavior only if I have chosen the "best for electronic..." option the last time I did a manual save. If I ever choose the "best for printing option" my macro will then cease desired behavior the next time it is run.
    Hope that helps clarify.
    2018-03-06T06:46:24+00:00
    I don't understand your question.
    The code using a SaveAs2 method works. Now you are pointing to an option on the Save As dialog that is not invoked by the code we have been discussing...
    So, please clarify what problem you are experiencing.
  3. Deleted
