Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
    2025-05-17T16:04:13+00:00
    This did sort it out immediately; Thank you, Larry
    2025-05-17T16:16:11+00:00
    I can confirm that the solution offered by Larry Rich1 is successful.
    I managed to restore the ability to close the browser by turning off the following settings, one by one, and force-closing Edge after each, in order to identify which action worked:
    • Start-up boost
    • Continue running background extensions and apps when Microsoft Edge is closed
    • Use graphics acceleration when available
    After turning off "Start-up boost" and restarting edge - no effect
    After turning off "Continue running background extensions" and restarting edge - no effect
    After turning off "Use graphics acceleration" and restarting edge - I could finally close Edge once more.
    I then re-enabled each option, one at a time, and found that Edge will now close.
    Like greenfid, my culprit was graphics acceleration. After toggling these settings back on, I can still close Edge.
    30+ people found this answer helpful.
    2025-05-17T17:29:54+00:00
    None of the supposed "fixes" have worked for me. Edge used to work just fine, so clearly it's a Microsoft problem and they need to fix it.
    2025-05-17T15:50:41+00:00
    Ok - since my post this morning - I reset Edge and it now closes. I do not know why it played up or why it works on the laptop, but if other people are having an issue - it must be something that has updated.
  5. Virginia M 42,585 Reputation points Independent Advisor
    2025-05-17T13:38:15+00:00
    Hello, I’m Virginia, a fellow user like yourself.
    Sorry to hear you’re experiencing problems.
    Does the problem occur when using InPrivate mode?
    Have you tried resetting Edge?
    Please try these cmds:
    Right click on start & choose powershell/terminal with admin & type/copy & paste these cmds one at a time then click Enter:
    SFC /SCANNOW
    DISM /Online /Cleanup-Image /StartComponentCleanup
    DISM /Online /Cleanup-Image /RestoreHealth
    SFC /SCANNOW
    Yes the Sfc cmd is run twice.
    10 people found this answer helpful.
