Sidebar tabs on right side, are missing in EDGE!
2022-10-02T16:08:51+00:00
I used to have tabs/sidebar on far right, now I do not!
How can I repair EDGE, or what needs to be repaired?
Thanks!
CarrmasDad
2022-10-05T07:59:55+00:00
Is it possible to enlarge the DARK words etc.
and change the size and tint of the light words etc.?
I answered a similar question a couple of weeks ago: Making all text on Edge webpage darker - Microsoft Community
You might find the solution useful.
2022-10-02T18:34:15+00:00
I opened Settings but I did not see APPEARANCE!
The settings navigation pane is hidden if the window is too narrow. You should see a 'hamburger' icon ≡ to the left of the Settings heading; a click on it should then reveal the settings menu. Or just make the window a bit wider.
DaveM121 947.9K Reputation points Independent Advisor
2022-10-02T17:32:59+00:00
Hi CarrmasDad,
They must have different settings in the Windows 7 edition, if you click the 3 dots at the top right of Edge, on the resulting menu, near the bottom, is there the 'Show Sidebar' option on that menu?
13 additional answers
    2022-10-02T20:42:12+00:00
    Where do you want to change the text color and size in Edge? YES! I want to change the size and also darken the text! If you want I will send you a CLIP!!
    Thanks!
    CarrmasDad2
    2022-10-02T20:34:51+00:00
    Hi Dave,
    You are right,
    Windows 7 edition, if you click the 3 dots at the top right of Edge, on the resulting menu, near the bottom, is there the 'Show Sidebar' option on that menu? you are right, and my side bar is working! Thanks!
    What did I do wrong? I now have this tan column, which I do not want! HELP PLEASE!
    CarrmasDad2
    ![](https://learn-attachment.microsoft.com/api/attachments/218bf755-8049-4d6e-ab8e-f32af324cc4b?platform=QnA
