Battery Degradtion : Surface Pro (5 , 2017) (I5, 256 gb)
2019-06-15T07:08:49+00:00
I just wonder if some of you who own this version of Surface Pro have the same issues like mine as in below:
ISSUE: Battery at full charge drastically degraded and swingsConditions observed lately:-The battery runs out within 1-2 hrs just by browsing websites/Youtube (tested on both Chrome&M. Edge)
-To fully Charge, takes only around 20-30mins (Est. full charge not accurate)
-Battery sometimes drops by a ridiculous amount E.G. by 20-30% in 1 sec.After checked with Battert Report run in CMDAt Designed Cap at : 45,000,
My Full Charge history as below (Noted that i tried to reset the windows and all previous history is gone so this is what i remember)
First bought (Jan,2018)
Full Charge 2018                                 : around 40,000 0 44,000
Full Charge 2019(Early months)          : Starting to drop to 35,000
Full Chrage as of the last few months : 25,000
Full charge as the last few days of notice: Swings from 22,000 to 9,000 life cycles at 383
Now i cant use it outside without charger. This is very frustating while working**.**
As my device is out of warranty, after searching online, the onl way is replacement at 500USD which seems ridiculus to me just because of battery. I bought this expensive device for the reason of long-term use. this is just a year and a half. Shouldn't it last for 4-5 years for its price?
If you have the same issues and any solutions/suggestions, feel free to share and discuss.
**Update 1 8/19/19:**I can't turn on. I lost my files those i didn't back up. I don't have any other computer to use.
Update 2 8/22/19: I just bought a new PC just to work. I cant wait for 1-2 weeks (Send to another country as  there's no microsoft HQ in Thailand) and spend 500USD for just battery replacement.
I kinda gave up and thought it was my fault back then. Now, if you have the same problems. Please up vote.
Update 3 9/1/19:
Seems like my battery is completely dead after testing at a computer shop.
Conclusion:
I am not a hardcore user. In less than 400 cycles, battery (all 4 cells) is dead.
The battery life of my surface pro lasted less than 2 years.
That means you have to pay 500 USD every 2 years. (Could have used this money to upgrade lol)
Maybe 2 in 1 tablets/laptops are not ready for practical use.
Maybe other brands are geting better.
Why do we have to refurbish/replace the device for just a battery which shouldn't cost more than 50 USD.
P.S.
For those who cant even turn the device on,
It's either the circuit is broken duee to defect/unfunctional battary
OR
The battery is completely dead
Worst case = both.
    2019-10-29T16:11:03+00:00
    One more failing Surface Pro battery here. Mine died in 26 minutes yesterday. It wouldn't turn back on after an hour on my Surface Dock. It only came back once I moved it to my travel charger.
    Surface Pro 5
    i7-7660U @2.5GHz
    8 GB RAM
    256 GB HD
  2. Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
    2019-09-25T10:28:32+00:00
    All you can do is exchange it. If you are in the US you should go to the closest
    physical retail Microsoft Store (there are also 5 stores in Canada and 1 each in
    London, UK and Sydney, AU) https://www.microsoft.com/en-us/store/locations/find-a-store - if you are not
    able to get to a store, contact support
    https://support.microsoft.com/en-us/help/4051701/global-customer-service-phone-numbers.
    Go to a Store if you can, it is the best option.
    2019-09-25T05:44:50+00:00
    I have the same problem, the battery is dead, i have aprox 584 cycles
    2019-09-22T21:30:55+00:00
    Thanks dave,
    I was asking for "the best practice as to when to have the Surface pro 5 plugged into the wall". (No docking station involved)
    For example:
    Going back to the old days it was a good practice to let a NIMH battery fully discharge before recharging. (I know the surface doesn't have a NIMH battery.)
    All I'm asking is: For a new Surface Pro 5, should I fully charge the battery (By plugging into the wall), then allow the battery to fully discharge, then fully charge the battery at the wall …….. repeat :>).
    I saw a note for battery usage:
    • Fully charge the battery,
    • Allow to discharge to 15 to 45%. (Don't fully discharge)
    • Recharge  to 100%.
    • Repeat  ….. > with the following exception:
    • Allow the battery to fully discharge at least once per month.
    Don't leave the surface  plugged in all of the time.
    Regards,
    Steve
  5. Anonymous
    2019-09-22T18:03:21+00:00
    My understanding is that the Surface Pro dock does not supply enough power to charge the Surface from zero/no battery, but the standard charger does.
