Battery Degradtion : Surface Pro (5 , 2017) (I5, 256 gb)
2019-06-15T07:08:49+00:00
I just wonder if some of you who own this version of Surface Pro have the same issues like mine as in below:
ISSUE: Battery at full charge drastically degraded and swingsConditions observed lately:-The battery runs out within 1-2 hrs just by browsing websites/Youtube (tested on both Chrome&M. Edge)
-To fully Charge, takes only around 20-30mins (Est. full charge not accurate)
-Battery sometimes drops by a ridiculous amount E.G. by 20-30% in 1 sec.After checked with Battert Report run in CMDAt Designed Cap at : 45,000,
My Full Charge history as below (Noted that i tried to reset the windows and all previous history is gone so this is what i remember)
First bought (Jan,2018)
Full Charge 2018                                 : around 40,000 0 44,000
Full Charge 2019(Early months)          : Starting to drop to 35,000
Full Chrage as of the last few months : 25,000
Full charge as the last few days of notice: Swings from 22,000 to 9,000 life cycles at 383
Now i cant use it outside without charger. This is very frustating while working**.**
As my device is out of warranty, after searching online, the onl way is replacement at 500USD which seems ridiculus to me just because of battery. I bought this expensive device for the reason of long-term use. this is just a year and a half. Shouldn't it last for 4-5 years for its price?
If you have the same issues and any solutions/suggestions, feel free to share and discuss.
**Update 1 8/19/19:**I can't turn on. I lost my files those i didn't back up. I don't have any other computer to use.
Update 2 8/22/19: I just bought a new PC just to work. I cant wait for 1-2 weeks (Send to another country as  there's no microsoft HQ in Thailand) and spend 500USD for just battery replacement.
I kinda gave up and thought it was my fault back then. Now, if you have the same problems. Please up vote.
Update 3 9/1/19:
Seems like my battery is completely dead after testing at a computer shop.
Conclusion:
I am not a hardcore user. In less than 400 cycles, battery (all 4 cells) is dead.
The battery life of my surface pro lasted less than 2 years.
That means you have to pay 500 USD every 2 years. (Could have used this money to upgrade lol)
Maybe 2 in 1 tablets/laptops are not ready for practical use.
Maybe other brands are geting better.
Why do we have to refurbish/replace the device for just a battery which shouldn't cost more than 50 USD.
P.S.
For those who cant even turn the device on,
It's either the circuit is broken duee to defect/unfunctional battary
OR
The battery is completely dead
Worst case = both.
    2019-12-24T16:37:00+00:00
    So very disappointed to see so many others having the same problem with their SP5 that mine has just developed. I was a huge Microsoft fan and with the SP2 became a bigger fan until that failed. I then bought the SP5 and thought what a great machine but you don't expect it to fail a little over a year later. I've read all of the other messages and replies here on this thread and it horrifies me. I'm a creative and certainly no 'techie' and wouldn't dare to try any of the supposed solutions suggested here. What on earth are we non-techs supposed to do with our very expensive now pretty useless pieces of hardware? We should not be expected to fiddle with all that is suggested if we don't know what we are doing - MS should be putting it right.
    Come on Microsoft please offer us all some form of assistance with this. We all spent a lot of hard earned money here investing in the name of Microsoft and we seem to be very badly let down by you. If you can launch however many millions of W10 OS, surely you can give us a fix for this.
    2019-12-24T10:50:08+00:00
    I have the same problem and agree 100 percent. If there is no solution from microsoft, I will never buy anything from them again. And I will tell everyone I know.
    2019-12-24T10:44:49+00:00
    Yes, I have exactly the same problem and have never been able to communicate directly with microsoft about it. I love this computer, but will never buy one again unless I receive some kind of response from them. It is absolutely unacceptable. I need this computer for my work, but it doesn't work! I hate it!
  4. Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
    2019-12-24T10:16:02+00:00
  5. Anonymous
    2019-12-24T01:10:30+00:00
    Same problem.  Battery going bad at only 197 cycles.  All updates applied.  Removed driver and reinstalled.  Non-removable batteries good for about 2 years makes for a very expensive laptop.
    Battery report
    https://1drv.ms/u/s!AkIGbWA-tH1Gkvkm8FXMOP3hym3mgw
    Feedback Hub
    https://aka.ms/AA6w83d
    FULL CHARGE CAPACITY 25,720 mWh
    CYCLE COUNT 197
