Surface 3 charging issues
2015-05-06T14:21:00+00:00
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Here’s how:
2015-05-06T16:58:56+00:00
2015-07-22T16:55:03+00:00
take a look at
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
2015-12-17T00:48:32+00:00
337 additional answers
    2015-05-12T06:40:06+00:00
    I've seen it lose charge when it says "plugged in, not charging" (including one on display in a Microsoft Store!), but never seen it lose charge when it says "charging".
    Incidentally, twice today I have closed the touch-cover only to find when I opened it a few hours later that the Surface had completely powered down, and booted from scratch when I pressed the power button.  All my power settings are for it to go into 'sleep' mode only.  hope it's just a bug.
