Surface 3 charging issues
2015-05-06T14:21:00+00:00
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Here’s how:
2015-05-06T16:58:56+00:00
2015-07-22T16:55:03+00:00
take a look at
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
2015-12-17T00:48:32+00:00
337 additional answers
    2015-05-09T15:31:28+00:00
    I'm having the same problem -- occasionally, if I unplug and plug the USB in a few times I can get it to charge, but its fiddly. Right now it also thinks its plugged in and not charging even though its not plugged in. As a result, its also crushing the battery -- down 50% in about 90 minutes of web surfing.
    Twice, when it was plugged in and charging, it decided it wasn't plugged in and shut itself down, too.
    Not so impressed so far. This seems like a software issue, not hardware, but a full reset hasn't corrected it. I'm going to bring it back for a replacement tomorrow...
