Surface 3 charging issues
2015-05-06T14:21:00+00:00
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Here’s how:
2015-05-06T16:58:56+00:00
2015-07-22T16:55:03+00:00
take a look at
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
2015-12-17T00:48:32+00:00
337 additional answers
    2017-03-10T16:54:54+00:00
    When I bought my Surface 3 I immediately began having problems.  I called Microsoft Support and one of the technicians told me about the 2 button reboot.  However, charging problems began recurring.  The cord was replaced and all was well for a period of about 6 weeks everything was fine.  Last week it refused to charge at all and I am now in the position of trying to save my data.  Is there anything I can do or is there information that will help me?
