Surface 3 charging issues
2015-05-06T14:21:00+00:00
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Here’s how:
2015-05-06T16:58:56+00:00
2015-07-22T16:55:03+00:00
take a look at
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
2015-12-17T00:48:32+00:00
337 additional answers
    2017-01-01T16:54:50+00:00
    I recently bought a refurbished surface 3 and was having the same charging issues as lots of folks here.  I spent $20 at Amazon on an aftermarket charger and better USB cord as many here have suggested.  Problem solved!
    Amazing to me that Microsoft is still exchanging tablets, wasting people's time with troubleshooting that doesn't work, and the like.  What a huge waste of resources and just goes to show that Microsoft has big weaknesses as a company!
    They should just send a proper charger to everyone who bought the surface 3 and be done with most/all of the charging problems.  My opinion of Microsoft has gone way down.
    But they aren't doing this.  So anyone who has a surface 3 that has charging problems, just pony up $20 and be done with it!  Who cares if it "should" be Microsoft's responsibility - move on with your life and enjoy the surface 3.  Here are the items that worked for me:
    https://www.amazon.com/gp/product/B0088HTYUE/ref=oh\_aui\_detailpage\_o04\_s00?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B01LCDJ7LG/ref=oh\_aui\_detailpage\_o04\_s00?ie=UTF8&psc=1
