Surface 3 charging issues
2015-05-06T14:21:00+00:00
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Here’s how:
2015-05-06T16:58:56+00:00
2015-07-22T16:55:03+00:00
take a look at
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
2015-12-17T00:48:32+00:00
337 additional answers
    2016-12-10T21:53:36+00:00
    I've had my Surface 3 for about a year and the charging issue has cropped up only in the past week.  I suspect a software bug.  Something has been stepped on.  You'd think MS would be past this OS nonsense by now.  Resetting the Surface 3 at the moment.  Fortunately it really is lightly used - I bought it mainly to have a mobile tablet form with full Windows 10 browser capability to get past app crap, but given the price of these things, it will be a cold day in heck before I buy another one.
    Very happy sticking with my Google Nexus 7 tablet - two + years and counting.
