Surface 3 charging issues
2015-05-06T14:21:00+00:00
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Here’s how:
2015-05-06T16:58:56+00:00
2015-07-22T16:55:03+00:00
take a look at
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
2015-12-17T00:48:32+00:00
337 additional answers
    2016-12-08T07:02:19+00:00
    My Microsoft Surface 3 has been loosing charge when it is plugged in and says its not charging but plugged in also. Ive been using a portable charger for it so I can keep a charge during three hour lectures and the charge port seems to be loose and I currently can't get it to even charge or turn on. Im going to take it to best buy because that is where I purchased it. I'm hoping they can replace the port and or fix the other bugs
