Surface 3 charging issues
2015-05-06T14:21:00+00:00
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Here’s how:
2015-05-06T16:58:56+00:00
2015-07-22T16:55:03+00:00
take a look at
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
2015-12-17T00:48:32+00:00
337 additional answers
    2016-11-05T05:34:07+00:00
    They ended up giving me a new Surface 3 and charger. I'd recommend to anyone just taking it into the Microsoft store, because they have no problems with replacing anything under warranty. First they thought it was the charging port, then they thought it was the charger. Next time, if there is one, I'll try your USB cord idea.
