Surface 3 charging issues
2015-05-06T14:21:00+00:00
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Here’s how:
2015-05-06T16:58:56+00:00
2015-07-22T16:55:03+00:00
take a look at
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
2015-12-17T00:48:32+00:00
337 additional answers
    2015-05-15T16:52:33+00:00
    One more thing: there were no known WiFi networks to connect to, so it shouldn't be that it was downloading a bunch of stuff in Connected Standby.  Maybe the WiFi adapter was burning all of its energy looking for a known network?
