Surface 3 charging issues
2015-05-06T14:21:00+00:00
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Here’s how:
2015-05-06T16:58:56+00:00
2015-07-22T16:55:03+00:00
take a look at
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
2015-12-17T00:48:32+00:00
337 additional answers
    2015-05-15T16:49:01+00:00
    Hi folks,
    I just received the Surface 3 and have been playing with it for a few days.
    Last night I put it away (closed the cover) and this morning I pulled it out and the battery was completely dead.  I did some research and tried the "powercfg /sleepstudy" feature and found the culprit which drained 89% of my battery in 12 hours:
    /batteryreport says that it was in "Connected standby"
    13:31:45 Connected standby 12:09:09 89 % 24,909 mWh
    /sleepstudy says it is the Network Controller, HD Graphics (which is weird since the screen was off), and SD Host Controller:
    Top Offenders
    Top 5 offenders, ranked by active time
    Marvell AVASTAR Wireless-AC Network Controller Networking 100% 12:01:00
    Connection Phase PDC Phase 100% 12:00:59
    Intel(R) HD Graphics (\\_SB.PCI0.GFX0) Fx Device 100% 11:59:47
    Intel SD Host Controller (\\_SB.PCI0.SDHA) Fx Device 89% 10:40:39
    Intel(R) USB 3.0 Host Controller Adaptation Driver (\\_SB.PCI0.XHC1) Fx Device 6% 0:43:15
    My question is: Are there going to be driver updates that fix this problem?
    My power configuration is default out of the box (sleep after 2 minutes) except for one change: I set it to never sleep when connected to a power source.
