Surface 3 charging issues
2015-05-06T14:21:00+00:00
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Here’s how:
2015-05-06T16:58:56+00:00
2015-07-22T16:55:03+00:00
take a look at
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
2015-12-17T00:48:32+00:00
337 additional answers
    2015-05-14T16:44:42+00:00
    This seems related to what I (a prospective Surface 3 purchaser who is waiting for the 128 GB, 4 RAM, LTE version) have read in one of the reviews at microsoftstore.com:  "The charging takes a) too long b) LOSES incremental charge when being used and plugged . . ."  I am curious if anyone else has found that the Surface 3 actually loses charge while plugged in and in use.
    It happened to me right now. Plugged in, says "charging"...and lost 60% of the power this morning.
