Surface 3 charging issues
2015-05-06T14:21:00+00:00
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Here’s how:
2015-05-06T16:58:56+00:00
2015-07-22T16:55:03+00:00
take a look at
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
2015-12-17T00:48:32+00:00
337 additional answers
    2017-03-10T20:44:29+00:00
    Nope. I've bought two 20AWG USB cables on Amazon, and they consistently worked for only about a week. My most reliable cable right now is the one that came with my Kindle Fire. Unfortunately, it's only about 2 feet long, making it really inconvenient.
