Surface 3 charging issues
2015-05-06T14:21:00+00:00
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Here’s how:
2015-05-06T16:58:56+00:00
2015-07-22T16:55:03+00:00
take a look at
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
2015-12-17T00:48:32+00:00
337 additional answers
    2016-11-03T01:42:58+00:00
    Ok, let's just cut to the quick here, the Surface 3 is **the worst pc I've ever owned!**This ridiculous charging issue has been here since day 1 and not a single useful solution has been posted. Microsoft doesn't give a toss and have dropped the 3 leaving us all in the lurch. It's flaky, unreliable, the BT mouse driver is always failing needing a hard reboot. The charging port is junk, the charger and cable are junk and I'm also on my second S3 as the first (which also had these problems) died spectacularly with a red screen of death.  It constantly needs rebooting, half the time it's running at 100% cpu due to MS background tasks.. The list goes on, but basically, this thing is a pile of dog doo.
    Owning a Surface 3 is like owning an old triumph motorcycle, fun when it works but spends most of it's time leaking and breaking down. It's safe to say I doubt I'll be buying another MS pc because frankly, they are just not that reliable. I've had junk pc's before, but that was simply poor specs, not reliability. I cannot know if it'll be charged when I get up, it won't charge during use.. kinda defeats the whole 'tablet mobile' thing, or even tethered for that matter if all it does is drain and die.
    It sucks and MS has done nothing to address this.. ZERO!!
    Way to keep customers.
