2020-02-02T03:26:26+00:00
  1. Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
    2020-02-03T14:08:09+00:00
    I know, it's a problem when they don't update the history page at the same time the bits are pushed out. I've complained for years.
    However, are you able to roll this new driver back and regain proper behavior (as a test)? That would be a smoking gun if those afflicted can roll back and regain functionality. Hope you will try this for me..
    2020-02-03T13:16:37+00:00
    That's another issue, the official MS information is far behind.
    https://www.google.com/search?q=surface+pro+7+firmware&source=lnms&tbm=nws
    2020-02-03T11:17:38+00:00
    What exact update? Can you provide a screenshot of your Update History please? As of now, the last updates shown on the SP7 update history page is for December 5. The Surface Laptop 3, however, shows Intel graphics driver updates for 1/30.
    2020-02-03T02:58:57+00:00
    This is a real problem with the latest driver, please arrange escalation soonest.
    Cheers.
  5. Anonymous
    2020-02-03T02:29:44+00:00
    I am also having this same problem. I am using USB-C -> Displayport on my Surface Laptop 3 Intel edition to display two external monitors via MST daisy chaining.
    When I have the both monitors powered on, they become Digital Flat Panel (640x480 60Hz) in device manager and I get no display from either. However, if I turn the second display off, it detects the correct "Dell U2414H(DisplayPort) from the primary and I am able to get a desktop display "
    This worked fine until the Firmware and Drivers update this weekend. (January 2020 edition)
